06-08-2023
12:39 PM
06-08-2023
06:41 PM
computergeek541
06-08-2023 01:18 PM
06-08-2023 12:51 PM
H@Shy-guy i am not sure if you have enough time to redeem your points. Try to redeem 15 ponts for $15, then you will have enough money to reativate a $15 plan
Redeem the points now, I was told it is quick.
If you see the $15 in your account, then go to change subscription and make the plan change to $15 , if you are not on the $15 plan yet
06-08-2023 12:43 PM
Convert 15 of those points to the account balance and change to the $15 plan. This would be problematic if you have a plan that is no longer available and you would rather keep it.
06-08-2023 12:42 PM
cheapest plan is the $15 plan...with a $5 credit, that's $10 you need to come up with to renew the plan for 30 days.
If your regular plan expires, you have 90 days grace to re-up your plan. After 90 days it's gone for good.
