4 weeks ago
Hi, I am thinking of changing my subscription from a 90 day $120 plan with 4gb per month to the promo 50 gb Canada-US 50 gb $34 per month . My questions:
- would I be able to still use the 240gb loyalty promo I was given?
- would the plan ever change price on me? I’ve been paying the same price for years.
- is there a 90 day subscription discount for this plan?
- with the Canada-US plan , does it work for roaming in the US without having to purchase and add-on?
3 weeks ago
4 weeks ago
@Jasonyu08 wrote:Hi, I am thinking of changing my subscription from a 90 day $120 plan with 4gb per month to the promo 50 gb Canada-US 50 gb $34 per month . My questions:
Technically, it is a downgrade in plan. Since you are paying $40/month right now and downgrading to $34/month. According to FAQ, you would lose the loyalty promo add on if you downgrade. However, some customers have downgraded to a plan (greater than $29/month) and still kept the loyalty add on.
No price guarantees and Public mobile has the right to increase price any time. However, Public mobile has rarely increase plan prices.
Not for this promo plan.
Correct. No need to purchase separate add on.
4 weeks ago
Nope. Say goodbye to that.
I've been here for 5 years and I've never once seen someone's plan change.
Nope.
Yes. Works like you were here in Canada.
4 weeks ago - last edited 4 weeks ago
1. no one know for sure, but according to some sources, plans over $29/month will get the 240GB bonus, so, with a $34 plan, you should be ok to keep that
2. while plan price can change, PM rarely raised plan price. It will usually grandfather the plan with the same price. In recent years, PM only raise the price for 1 plan only, it was the $10 plan change to $13, but that was after like 3 years when the plan was first introduced
3. there is no 90 days option for this plan
4 weeks ago
You only lose bonus data if u downgrade plan which u are not. The plan might change but not for a while and mostly like grandfathered. No more adds on when you go to the US. Calling texting and data US-Can and vice versa are included in the plan. Best can/us plan other right now
