4 weeks ago
why is my phone seemingly disconnected even though I make automatic payments and then when I log in it will then work again!!!!
4 weeks ago
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/2247
4 weeks ago
hi @Nuka So, you login. My Account and did you make a payment manually to get the service back?? if you didn't make a manual payment and the service just work, it is weird
