Change plan
BCoombs
How would you go about changing your subscription before the original plan’s SIM card is delivered?
I cannot access the app without the new SIM. For reference I am looking to update to the 20GB Canadian subscription plan before the boxing week deal ends.
Thanks
7 REPLIES 7
@BCoombs wrote:
I am into the second day waiting now - hopefully news soon.  Thanks for the comments!
If they don't reply by the end of day, do a follow up message using the words FOLLOW UP in the subject line and if you happen to have a reference number, add that too.
BCoombs
@BCoombs wrote:
I have already done that, but am awaiting response. Any ideas on wait time - certainly not helping that it is a holiday week.
As per one of the Oracles here, they seem to be on time with respect to responding to customers. Usually a 2 hour wait or so. However, being boxing week, I'd probably think much longer.
Your mailbox is here, keep an eye on it.
hi @BCoombs
usually around 2 to 4 hours.  If you waited over 4 hours and still no reply, message them again
BCoombs
hi @BCoombs
since your plan was not fully activated yet (you are still waiting for the sim card), support agent can likely help
you can submit  ticket by direct message:
Chalupa_Batman
Thanks
Hello @BCoombs
So, this is how I'm viewing your question. You purchased a plan, SIM card is being sent by mail. You haven't got the SIM card yet but found a plan you're prefer over the one you originally picked? Since your plan hasn't started yet, best to reach out to a CS Agent to change the plan before you register the other plan.
