12-30-2024 12:34 PM
Hi, I want to upgrade from the $34/50GB plan to the $35/75GB boxing day offer; I already deployed $15 in points for the next billing cycle in 2 weeks on the $34 plan; will I lose it if I change plans or will it rebill for the new $35 plan using my $15 rewards; if that's the case I will not upgrade so I don't lose my $15 reward points. Many Thanks for your help.
12-30-2024 12:41 PM
Awesome! Thank YOU very much!
12-30-2024 12:35 PM
hi @pm101
if the $15 is showing as Available Funds on My Account, then you won't lose it and you can upgrade the plan without trouble
