02-27-2023 10:22 AM
The old loyalty plan was better, does changing plans automatically opt you into the new point system?
Last topic was from 2022, has anything changed since then?
Plans
02-27-2023 11:54 AM
@IWorkForRogers , also ignore the points emails should you get them. For some accounts they are being sent out in error. If you see 0 points earned that is an indicator of a errant email.
02-27-2023 11:16 AM - edited 02-27-2023 11:16 AM
As long as you DON’T click on switch to the Point System you are good to go.
02-27-2023 10:27 AM
HI @IWorkForRogers Ok to change plan without worry about your old rewards system. Switch plan and rewards system is same. My family member just switched one last month too and keeping the old rewards system
02-27-2023 10:23 AM
@IWorkForRogers No it doesn’t you can keep old rewards . I can confirm I just switched to the 15GB for$40 plan and kept my old rewards
02-27-2023 10:23 AM
@IWorkForRogers nothing changed. Changing plan would not affect your rewards system. You will be on the old system even you make plan change
No worry, go ahead
