Change Subscription on renewal didn't work
hlpnghnd
Change in subscription was done last month for the option to change on renewal. Today 19-June is my plan renewal date but subscription didn't change. Payment deducted as per pervious plan only. Can anyone please help resolving?
19 REPLIES 19
hlpnghnd
Thanks @softech
hlpnghnd
true.. Thanks
@hlpnghnd   of course you don't need to wait 30 more day  🤣
PM support are reasonable and they helped.  Glad all sorted out. Now, you can enjoy more data? Have fun
hlpnghnd
yup!!
@hlpnghnd  Woo hoo happy you got it all sorted out
hlpnghnd
yes @Handy1 , they just did!
hlpnghnd
I can't  wait for another 30 days @dust2dust , hopefully @CS_Agent will change the plan today
@hlpnghnd  Ok good , hopefully they will get straightened out for you quickly
hlpnghnd
I did @Handy1 and got response from @CS_Agent with the questions to change the plan. I have just answered and waiting for plan change by @CS_Agent
dust2dust
Do you see any evidence of the intended plan change? Were you changing down in plan cost? Are you willing to wait another 30 days? Set it up for the future change and then take a screenshot of the set change. I wonder if the plan change got dropped somehow with the new system.
@hlpnghnd  Please message support to get it fixed
Message support directly
  • while your already here and logged in the community you can send a private message   To CS_Agents click >>>here.<<<
hlpnghnd
Thanks @softech PM took the old plan amount confirmed with credit card. I need to contact PM support
hlpnghnd
@Handy1it says few seconds ago and the plan is still old, seems new plan hasn't been applied yet
hlpnghnd
@esjliv thanks for the reply and info
hlpnghnd
@hlpnghnd   you sure PM took the old plan amount ?  Confirm with your credit card first
if so, it is possible that the new My Account update has cleared out the previously scheduled plan changed.
Since it is still day 1 of the new cycle,  PM support likely can help to change back to the plan you want, you just need to open ticket to engage them
@hlpnghnd  If your renewal is today it’s possible system just hasn’t up dated yet but try this
simply try refreshing the page to check data plan / mins / add ons
if it doesn’t display correctly please
@hlpnghnd - if today is your renewal day, wait until later this afternoon for your account to complete its renewal process to see it reflected on your account properly.
You may also check 611 for the data balance, as this may be an indication on what plan you are on.
Edit, where do you see the payment of the old amount was taken? In your My Account? If so, then it does appear the new plan did not register correctly.
NOTE _ WE ARE NOT CS_AGENTS here on the community!
The 2 ways to contact the Public Mobile Customer Support Agent (CSA)_Team are below:
1 -  Normally Faster - use this link to: Get Help With Public Mobile Chatbot], OR
2 – Slower - Use this link to: Contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here: Private Message to Public Mobile Customer Support Agents (CSA)
hlpnghnd
@hlpnghnd wrote:
Change in subscription was done last month for the option to change on renewal. Today 19-June is my plan renewal date but subscription didn't change. Payment deducted as per pervious plan only. @CS_Agent please help resolving
