12-28-2024 09:27 AM
Hello!
my new subscription cycle starts on dec 28 (today). But why my data didn’t start from 0gb?
12-28-2024 10:57 AM
Mine did that a couple days on renewal. Close app, clear cache and was then showing zero. PM has cache issues.
12-28-2024 10:14 AM
12-28-2024 10:04 AM - edited 12-28-2024 10:05 AM
@Phil_Adelphus wrote:@Aizha That's normal, it's thought to be a buffer and will not count against your data bucket. When my plan recently renewed there was 100MB appearing to be used, which went down to 5MB a couple of days later. Others have reported the same thing. If it really concerns you then you can open a support ticket at the chat icon bottom right of this page for confirmation.
@Phil_Adelphus He is showing 5.75 of 6GB used. That's more than a buffer. More than likely the suggestion by @eddieO will fix it. @Aizha
12-28-2024 09:34 AM
12-28-2024 09:31 AM
@Aizha it's likely just a caching issue. If place your finger near the area that shows 5.75 (for your screen) and drag it down it should refresh or you can go to your phones settings and go to apps and locate PM and clear the app's cache and then log back into the app
12-28-2024 09:29 AM
