11-02-2021 05:12 PM - edited 01-04-2022 05:17 AM
I transferred my number from eastlink yesterday and I cannot send or Phone calls
11-02-2021 08:23 PM
@Tadaley wrote:I transferred my number from eastlink yesterday and I cannot send or Phone calls
Have you performed a Reset of your Network Settings yet?
Also, is it possible your phone locked to Eastlink? Contact them to unlock it for you. You will need your imei number, dial *#06# to get it.
And just to be sure...Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
11-02-2021 07:37 PM
Do you have any services? Or are you just not getting incoming calls? If you cannot use data, send or recieve texts and calls then you have a different issue.
Does your eastlink sim card still work? If it no longer works then your phone number has been successfully ported into your account.
If you have no working services then you have a sim card provisioning issue that only pm customer support can resolve. Contact customer support as previously provided and type in "sim card not provisioned upon activation" and "human" and follow the prompts to submit your support ticket.
11-02-2021 07:17 PM
@Tadaley Just want to confirm, can you make outgoing calls?
and when people tried to call you , you didn't receive it, right?. but do they hear your Eastlink voicemail or your new PM voicemail?
is Mobile Data working?
What is showing on your phone screen? No network? SIM not provisioned?
11-02-2021 06:24 PM - edited 11-02-2021 06:51 PM
Please don't make any adjustments to your APN settings unless you're having data issues. That cannot fix issues with phone calls. Further, although you asked for a number to be ported in, the issue here apears to be with the Public Mobile service not being activate properly. So while CSA may be needed, this isn't a number porting-specific problem since outgoing calls aren't working either.
11-02-2021 05:41 PM - edited 11-02-2021 05:42 PM
11-02-2021 05:38 PM - edited 11-02-2021 05:39 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
This is quick and simple,
if you can't fix it you have to Contact Customer Support Agent by CS_Agent, and Explain your issue to
they can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent, and Submit a Ticket
Good Luck...
11-02-2021 05:37 PM
I did receive the messsgd from Eastlink and I did reply yes
11-02-2021 05:36 PM
Yes, I did receive the messsge from Eastlink and I did reply yes
11-02-2021 05:18 PM
Was that Easylink Mobile or Homephone?
If Mobile, you should have received a text and you need to reply within 90 mins. Did you got that?
If Homephone, it might take couple days, 3 business days to 7 days
There is a number you can call to confirm the porting status..they will advise what to do or re-trigger the process if it was Mobile and you missed the text i will private message you , please check your Community inbox on the top right envelope icon
11-02-2021 05:15 PM - edited 11-02-2021 05:22 PM
Did you get and reply Yes to a texto from eastlink to approve the transfer?
If not the port is not complete. I'll send you a phone number to check and restart the process if necessary. Check your inbox.
Edit: If you're asked to contact PM to reinitiate the request, open a ticket via:
