Calls and text
Options
02-28-2025 06:06 PM
Can only recieve calls. When try and make calls or text just get message that not connected to network.
Phone recognizes my public mobile sim card
Labels:
Service
1 REPLY 1
Options
02-28-2025 06:09 PM
make sure you remove the sim card from your old carrier, if old one is esim, disable it
then Reset network settings and try. And if physical sim, always good to test on another phone
