Cellular Data
Evelyn1466
I am using an eSIM. After being abroad for a month and returning, my phone can make calls, but the mobile data is not connecting. How can I fix this?
@Chalupa_Batman wrote:
Just tagging @computergeek541 to remove personal info.
I've taken the picture away from the thread, but unfortunately, the information is still accessible to anyone who looks.  This information isn't something that I have the ability to delete.
Chalupa_Batman
Second, sometimes being away and using another service providers info with the same phone can mess up some settings. Try going into your network settings and reset the network and reboot. This can give it a fresh look at the PM settings.
slusagm
remove your screenshot, you have your personal data there
it is best to disable your other line (1-866), then set the PM esim as Primary as right now it is set as something else
