Cannot receive incoming calls. Missed the tow Truck
SuzanneFar
New in Town / Nouveau en Ville
Please help, I’ve been using my public mobile number for two years and the majority the time I do not receive my incoming calls. I saw a post that said to message the MOD to have them refresh the network? I have not transferred from another device provider. I have tried my SIM in another device same problem.
CountyDownIeUk
Are you in the same area during the “majority of time” ?
Try it.
What brand and model of phone do you have?
Has it ever been repaired? Antennae may have been damaged or disconnected.
Hmmm that’s a good test!
How many bars are you getting?
How about friends or neighbors at your same locations?
Check here for closeness to towers.
RCO
fwiw ,
1
Depending on where You Live
 It is good thing to Reboot your Phone
if you are traveling between Towns/Towers ! Rural Especially
2
If you have a Phone that is even a couple of years old
It is good to reboot/restart it now and again
and
3
Also Check for Updates
Cheer
dabr
@SuzanneFar   If this issue has been going on for almost two years (even if intermittently) then you should really have contacted customer support long before now as it maybe that your SIM needs to be re-provisioned, however, hopefully you've now submitted a ticket.
@SuzanneFar  can you sign into self serve ? Does it say if your account is active or suspended ?
if you need to reach support here’s a link
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here
  • you can send a private message to our  CS_Agents by clicking here.
