Calls
Carmel2
I'm unable to receive incoming calls and text
Rajaji
In these cases the best option to try is restart and check your account is not suspended. If these both are done then contacting CS_Agent is best way to resolve the issue.
Glad it's working fine now.
@Carmel2
Check to see if there is an outage in your area:
https://istheservicedowncanada.com/status/telus/map
If not then contact a CS_Agent to investigate your issue.
Chalupa_Batman
Hey @Carmel2
Did you just sign up with Public Mobile? Or a long standing member?
