12-26-2024
08:38 PM
12-26-2024
08:44 PM
computergeek541
I just signed up for a Can-US-Mex plan. I am trying to make a phone call to the US from Canada. Every time I dial my friends number it keeps saying that my number cannot be completed as dialed. I am using an iPhone 15 Plus does anyone know what could be causing this issue?
12-26-2024 09:02 PM
@Phil_Adelphus It looks like you are most likely right. As I was able to make phone calls to some other US numbers and they all worked. So I guessing it must be on there end.
12-26-2024 08:54 PM
@Cam24 You can contact customer service by opening a ticket at the chat icon bottom right of this page, or if that doesn't work send a private message using this link
Their hours are 9 a.m. to 10 p.m. eastern time so you likely won't get a reply tonight.
12-26-2024 08:51 PM
Is this all us numbers or just the one? And you verified that you have the can-us,m-mex plan?
12-26-2024 08:49 PM
@TheSterlinger I am making the call from Canada so I currently connected to the PM network. I have my network selection to automatic.
12-26-2024 08:48 PM
@Sansan I can make calls long distance calls and local in Canada. it just looks like I can't make calls to the US. I have tried to turn off/on my phone and have tried turning mode off/on airplane mode so far. I am not sure what else it could be.
12-26-2024 08:45 PM
@Cam24 Are you able to call any other US number, is it possible the problem is at the other person's end?
12-26-2024 08:44 PM
@Cam24 did you reboot phone? Try airplane mode and and off and try again. Can you made local calls?
12-26-2024 08:43 PM - edited 12-26-2024 08:57 PM
Try putting a 1 before the phone number and reboot phone to see if it works.
