12-07-2024 11:49 AM - last edited on 12-07-2024 05:36 PM by computergeek541
Hi folks.
I didn't have this problem on my old provider but ever since I moved over to Public Mobile, if someone sends me a photo or image, it'll show up in a separate SMS thread than the texts.
How do I fix this. I'm on an Android Google Pixel 6.
Thanks!
3 weeks ago
Just to restate my issue.
For some contacts, if the send me a TEXT SMS it comes in as 1 thread
If they send me an SMS with an image it'll go on another thread as a GROUP that includes the sender + myself. So if I respond on that thread, I get an echo of my text from ME!
I am using Google's Messages app.
I do have MMS enabled
sorry none of the following worked
1. deleted all SMS threads to contacts that have this issue
2. cleared cache and reboot
3. I tried turning off RCS but then I don't get any images.
12-07-2024 01:23 PM
hi @Ray_Gar1 Reset network won't help, it is an app problem. Tryclear cache first. If not, as said earlier, you need to uninstall Google Message first, reboot and reinstall
12-07-2024 01:20 PM - edited 12-07-2024 01:21 PM
You might want to try resetting the Network setting and see if that helps.
If you have home wifi, you will need to re-enter the wifi password again on your phone.
12-07-2024 12:46 PM
I have that set and rebooted. Still the same.
Wondering if clearing the cache works, will try to test that out with someone that I have a duplicate SMS thread with to try.
12-07-2024 12:44 PM
It doesn't happen with all, only some people.
12-07-2024 11:57 AM
hi @Ray_Gar1 backup all the important texts first
then uninstall Google Message, reboot phone and reinstall the app
12-07-2024 11:55 AM
@Ray_Gar1 Ensure you have MMS enabled and reset network settings and reboot the phone see if that helps
