03-05-2025
08:04 PM
03-06-2025
12:25 AM
computergeek541
I have rhe Can-US-Mex plan and will be in Mexico for a couple weeks. What is the dialing process for someone in Canada to reach me? Is it as simple as dialing my number? Thanks in advance.
03-05-2025 09:04 PM
Ok cool thank you!
03-05-2025 08:58 PM
Thanks TheSterlinger and hairbag1 for the quick replies.
03-05-2025 08:29 PM
VoLTE no required in Mx as only USA has retired 3g...not Mx or Canada.
03-05-2025 08:14 PM - edited 03-05-2025 09:06 PM
There should be no special dailing needed. Technically no one knows your out of the country so they would just dial your number as normal. The call will be placed because you have the roaming plan in Mexico.
Ensure you have roaming turned on.
