Cannot connect to internet since plan renewal April 24 2019..Charged for data but data plan did not
Veronacoffee
2 REPLIES 2
Veronacoffee
Plan paid up April 24  Only 2 Mb data of 500 Mb used . Appears this usage is associated with attachments to texts.  Have no mobile internet since plan renewed for May.  Sent notice to  moderator last night but no response yet
will13am
@Veronacoffee , the amount of data remaining in an account is found in the overview tab of the self serve account.  Do you see a line item showing how much data was used?  If not then according to the system, it has all been used up.  There were issues with accounts renewing but the data counter did not reset.  If you are out of data and you suspect the data counter reset issue affected your account, you need to get the moderator team to investigate and correct the problem.  The moderator team can be reached via private message using this link.  Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
