Cancel my account
10-20-2022 06:50 PM
I am out of the country in Mexico and would like to cancel my account ,my PM number doesn’t work in Mexico. I can not log onto my account starting with user name , I am not receiving the 6 digit code to reset my user name or password . I would like to get access to my account (manage) and cancel my credit card on file to discontinue my account.
My Account
10-21-2022 11:26 AM
@Deborah2 wrote:how do you do that
@Deborah2 do you want to cancel the service or just engage PM support?
to engage PM support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
10-21-2022 11:24 AM
how do you do that
10-20-2022 08:05 PM
If you know your 4 digit account pin and if you can somehow dial 1-855-4pu-blic from where you are then you can turn off autopay in the basic dial-in account system.
10-20-2022 06:55 PM - edited 02-17-2023 09:19 AM
Hi @Puerto22 Please open ticket with PM CS agent and they will reset the password for you
to open ticket with CS Agent:
at : https://publicmobile.ca/chatbot.
start by typing : Forgot Login Information
You can then disable Pre-authorized payments once you can login to My Account
10-20-2022 06:53 PM
![](/skins/images/34AB3B0FE78BBE11DBF186F131BC3766/responsive_peak/images/icon_anonymous_message.png)
