12-21-2023 06:26 PM
1. Does this plan cover unlimited usage for calling, *data and texts if you are positioned in Canada or if you are positioned in the USA? And calling to USA to Canada and Canada to USA is unlimited and included? *Yes I realize not unlimited.
2. Are there or has there been any Canada - USA plans for a lower per month cost? Is this a competitive price or does the competition have something better?
3. And LD Add Ons .... they don't expire until used up? And if positioned in the USA they can be used as well?
12-21-2023 08:07 PM - edited 12-21-2023 08:07 PM
You can only call Canada and the US when in the US (your long distance add-on's won't work to call the UK from the US, for example).
Honestly, $65 is not good value. Canada/US plans used to start at $50, and there are other carriers offering much better deals. Freedom has Canada/US plans starting at $34/month.
12-21-2023 06:29 PM
1. unlimited calls (Canada and US)) and texts but not unlimited data, so no reduced speed data after the data used up
2.They had cheaper Canada US plan at $50 before but no longer. Look like they try to leave more Camada-US plans for Koodo and Telus
12-21-2023 06:28 PM - edited 12-21-2023 06:29 PM
@Grinch It’s unlimited calling and texting but not data . It will stop once the 60GB is all used up unfortunately .
add all 5G plans that include CAN/US stop the data after bucket used the non CAN /US 5G plans have unlimited data throttled to 512kbps
