12-31-2024 03:30 PM
If I purchase a plan that has unlimited minutes in US, Canada and Mexico - there will be no roaming fees?
12-31-2024 03:45 PM
Hello @Lizard12
The Canada US Mexico plan have zero roaming charges. I had the Canada US myself and I was able to make TONS of calls, text messages and use my data while in the US and there were zero extra fees. It's like Roam Like Home. Depending on where you're going, just make sure to check here how to connect to Telco's in the US and Mexico so you have no surprises when you get there.
12-31-2024 03:39 PM
hi @Lizard12 no extra roaming fees when you use the service in US and Mexico
12-31-2024 03:34 PM
There are no roaming fees, as your plan is prepaid.
