Canada-US plan
PurplePanda
I will be heading to the US and I have the Canda-US plan.  Do I have to do anything to switch over once I'm there or does it automatically switch over?
thanks,
SourDude1234
Hi there @PurplePanda
Ensure that your network is set to automatic and data roaming is turned on. It should connect automatically but it is not a bad idea to restart the phone just incase. Have a nice trip!
maple_leaf
Hello @PurplePanda , What they said, plus I've attached a link to U.S. Roaming troubleshooting should it be of help:
U.S. Roaming Troubleshooting:
https://www.publicmobile.ca/en/on/get-help/articles/us-roaming-troubleshooting
Chalupa_Batman
Just to add, it never hurts to do a reboot while you're in the US just to make sure you're connected to the first network it finds.
dust2dust
I suggest networks on automatic so that the phone can connect to either AT&T or T-Mobile wherever the coverage is better.
@PurplePanda  Just ensure data roaming is turned on in your phone settings . And make sure your connected to T mobile
dust2dust
Set network to automatic, turn on roaming data, to be safe set to 4G LTE etc. Then, do you know if your phone has been enabled for volte yet?
