06-03-2023 11:32 PM
I have set up to emails to get the same outcome for both “let’s complete your account” when I log in but then after I get there it will not let me do anything to set up the account and I can’t try again because it says the email is linked to an active account 🤷♀️
3 weeks ago
When you activate a new SIM on your app…you have created an Eversafe ID account.
If you are a long time member, you can create an Eversafe ID by clicking on Sign Up when you try to login to your account on eversafe.id.telus.com.
3 weeks ago
Hi BKNS27, I am having this exact issue!!! Can you please tell me how to create an Eversafe ID before starting to activate the SIM/pick a plan then go through the 6 steps before completion of your account?!!!!
06-04-2023 08:07 AM
@Lynne4 wrote:I have set up to emails to get the same outcome for both “let’s complete your account” when I log in but then after I get there it will not let me do anything to set up the account and I can’t try again because it says the email is linked to an active account 🤷♀️
@Lynne4 each account requires a unique email. Is the email you are using an email attached to an existing account?
06-04-2023 12:26 AM - edited 06-04-2023 12:33 AM
Are you using the PM app or on the PM website?
You need to create a Eversafe ID before starting to activate the SIM/pick a plan then go through the 6 steps before completion of your account.
06-03-2023 11:36 PM
@Lynne4 you are trying to setup a new account to activate new line? or you have trouble setting up EverSafe ID to access an existing My Account?
