4 weeks ago
One of my friend joined PM in March and applied my referral code in the registration. But untill now I have not received the referral reward yet. Would like to know what's happen?
3 weeks ago
They registered on March 2 and 14th/24. My renewal date on 12th with autopay.
3 weeks ago
HI @4Siu1
submit a ticket and check.
also, did you check your My Referrals page using the browser (they don't have it on the app)
it shows you how many new referrals you got in the last 12 months. do you see 3 or 2 for March?
3 weeks ago
One registered in Noverber/23, 2 registered in March/24. All of three had applied my code while registered.
3 weeks ago
Viewed activity in my reward account . 2 friends applied my code to register on March 2 and March 14 but I only have added 1 reward points. So for, 3 of my friends have applied refer-a-friend code. Please help!
3 weeks ago
HI @4Siu1
if missing the one from March 14, that is long and you should have got it twice
please ask support agent to check. Give them your friends phone numbers and ask them to check
Please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
3 weeks ago
Three of my friends use my code while registered. All of them got $10 credit. I have got the reward points from 2 of them but just missed the reward point from one who registered on 14th March. Please help!
4 weeks ago
Did you get a text saying that someone used your code?
What day did your friend use the code? And when does YOUR plan renew?
You get the point when your plan renews, not theirs. (However is has been over 30 days, so should have got the point by now) But maybe it they signed up right before you plan renewed and the system did not register it in time?
4 weeks ago
hi @4Siu1
did your friend get the $10 credit on his my account?
if you login to My Account , go to My Referrals, it will show you how many new activation you got in the last 6 month, you see an increase in one of those months?
4 weeks ago - last edited 4 weeks ago
Chances are they might have entered the wrong code. The mixup could be 0/O, 1/I or S/5 so they should contact a CS_Agent to adjust.
But login to your account and see if you got the 1 point/month for the referral. In any case, if it was entered correctly. You should have gotten a notice indicating
“Cha-ching! You just added to your Refer a Friend Reward-way to go! Keep referring to earn more. View your Reward account.”
4 weeks ago
@4Siu1 Did your friend get their reward for your referral? Are/were you on the old rewards system or the newer points system?
4 weeks ago
Your friend will need to open a ticket to find out what happened.
