03-03-2024 03:19 PM - last edited on 03-04-2024 09:49 AM by Dunkman
03-08-2024 06:05 PM
I am having the same issue.
Switched over Tuesday and has not resolved. Tried the SIM in multiple devices, tried a reset, and have powered down and take SIM out multiple times and still not recieving messages.
Also only getting mostly 4G in a 5G zone. Logged a ticket and was advised up to 72 business hours to address the issue.
Will most likely be switching to a new provider by tomorrow. No cheap rate is worth this hassle.
03-04-2024 10:09 AM
Yes I tried network reset several times unfortunately did not work. Tried a new esim as well .
03-04-2024 09:46 AM
If not tried, reboot your phone. Maybe try a network reset of phone. Note this will erase any saved Wifi passwords.
03-03-2024 03:56 PM
Hi yes I can receive calls to Roger's even and other carriers and I can message to and from other carries I can even send to Roger's only thing not working is receiving text from Roger's numbers. Have tried eith 3 different Roger's users and none come through
03-03-2024 03:54 PM
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
