Can't log in to speak with agent or ge ticket
Paulraposo
Chip was empty and had to change providerI need help to geta refund on the plan I bought for 45.oo can someone help me
just message PM and if the service was never setup properly , we know that PM will usually provide full refund
Paulraposo
The problem is that I can't log in because my chip is defective
Paulraposo
I already changed provider I just want a refund
eddieO
@Paulraposo if you are looking at refunds or account related changes you will need to reach out to a CS agent. You can open a ticket through the Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
slusagm
what is Chip was empty?
you might not need to change provider, PM can help to fix it.  But you need to message them first here
