09-16-2023 09:33 PM
Just set up my SIM card today.
texing is working perfectly however when I call, the call goes through but they can’t hear me and I can’t hear them. Also, on my iPhone the speaker option is blacked out so I can’t use speaker phone. Also having issues with FaceTime. I have the 15$ plan.
tried the SIM card in my partners phone and everything seems to work on his phone. Any ideas?
09-17-2023 04:30 AM
Did you try with an airport or Bluetooth headphones or headphones on old iPhones with a jack?
Certainly sounds like the speakers have had it but use headphones for now.
09-16-2023 09:39 PM
09-16-2023 09:38 PM
since it works on your partner's phone, it is a problem with your device, could be a speaker problem
But don't give up, start with running on iOS update, make sure it is the latest one. If that does no help, I suggest you to try Reset your phone to factory default and setup the phone again
09-16-2023 09:34 PM
HI @KAH53
it looks to me it is a device problem since you said your iPhone speaker option is not there. Try to reboot the phone
