07-15-2022 07:58 PM
Amy help for this? The only options I get are the $35 & $15 in the self-serve
07-16-2022 02:57 AM - edited 07-16-2022 02:59 AM
@Buckem09 wrote:Amy help for this? The only options I get are the $35 & $15 in the self-serve
My opinion is this:
In addition, to @hTideGnow comments that the arrows need to be clicked on to see additonal plans, customers also need to click/use the arrows to select the plan. This doesn't make sense to me. The plans should be selectable by clicking/touching/tapping on the plan details. The current implementation essentially equates to using a scroll bar to make the selection, something which I don't ever recall seing on another website
07-15-2022 08:24 PM
07-15-2022 08:12 PM - edited 07-15-2022 08:13 PM
To add to what others above have said,
If you are on mobile, the arrows are for right/left.
Look for: (>) or (<) symbols in yellow circles.
After you scroll pass the “Recommended” plan, you'll see all the other ones.
07-15-2022 08:12 PM
tried other browser and clear cache and cookies and use one page inPrivate mode,
and use the down arrow to scroll down
07-15-2022 08:11 PM - edited 07-15-2022 08:26 PM
@Buckem09 Yes, as mentioned you need to click on the down arrow and the plans change based on pricing. You can go back to a previous plan selection by using the up arrow. It's a bit confusing at first view.
edit: nvd..misread that you are wanting to change to the $50 plan.
07-15-2022 08:00 PM - edited 07-15-2022 08:00 PM
Hi @Buckem09 there are little arrows to scroll up and down, did you try that?
If the arrows not showing or not working, try a different browsers, maybe Edge or Firefox. Or try Incognito mode
