10-02-2024 02:17 PM - last edited on 10-02-2024 03:10 PM by computergeek541
"An existing EverSafe ID already exists with this phone number."
How is it that I can get a phone number from Public Mobile, and it's in use by someone else for their Eversafe?
10-02-2024 02:26 PM
you want to use another number to receive Eversafe 2Fa on your family account?
each number can only associated with 1 account. So, if what was what you were doing, you can't. But you can use email to receive 2FA code, hope this helps
10-02-2024 02:24 PM
@randomusername1, definitely sounds off, you should contact a CS agent to see what this means and have them straighten it out. To open a ticket through the Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
