01-06-2026 11:25 AM
Hey can you link or help me with this information please?
01-06-2026 12:07 PM
@SlowlyInsane wrote:How do I set the voicemail to a US number? Please message me... Thank you.
you meant setting forward to US?or check voicemail in US?
you cannot forward to US number. But you can still check voicemail when you are in US. If you have a Canada US Mexico plan, just press and hold 1 as usual. If you don't have such plan, you can call yourself from another phone, click * when you hear the greeting and enter voicemail PIN
For blocking number, you can block the number on the device, but it will still send the call to your voicemail
or you can use this check:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Lenny-the-Telemarketers-worst-nightmare/m...
01-06-2026 12:00 PM
Go to Voicemail settings on your phone and try to change number there (android)
01-06-2026 11:26 AM
