Activate eSIM and Manage Plans Without the App
10-02-2024
01:44 PM
10-02-2024
03:11 PM
computergeek541
Hi there,
Since I'm not from Canada, my App Store is limited to apps available in Europe, and the Public Mobile app is not available there.
Before subscribing to a plan, I wanted to ask: Is it possible to activate an eSIM and manage subscriptions entirely through a browser, without needing the dedicated app?
Thanks for your help!
Joining Public
My Account
10-02-2024 02:02 PM
hi @hi_winter
you need to use the app to subscribe for sure, especially you are subscribing esim
the app will try to install the esim for you, but if you are having a friend to help you subscribe, your friend has to stop the app from automatically install the esim for your
PM will still send out a Welcome email with the esim QR code. You can then scan the QR code to install the esim
10-02-2024 01:56 PM
Hi @hTideGnow,
Thanks for the quick response.
Since I could get started with an eSIM, I’d prefer this option if possible.
So, if I understand you correctly, the only workaround is this trick, and the app is always required at some point?
I noticed on my iPhone that you can add an eSIM using a QR code. Can’t I just use the code you mentioned after subscribing to a plan and scan it directly?
10-02-2024 01:51 PM
@hi_winter once your account is active you can manage your account through the website, so you won't need the app afterwards. To active your account you're supposed to do it through the app but you can contact a CS agent, tell them you need help activating, they should be able to do it for you. When you are ready you will need to open a ticket through the Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
10-02-2024 01:49 PM
hi @hi_winter
better to use physical sim in your case
in your case, you need to ask a friend to help to setup , ask your friend to download PM app and setup for you
you can still activate esim on your friend's phone, but you have to stop right before the moment the app try to install esim, which is tricky. Once stopped at the correct moment, you can then use the QR code from the Welcome email to install the esim on your phone
but for sure, it is easier to activate on physical sim
