Can’t add funds to account
ChristineC_24
Hi there,
Trying to add custom amount of funds to account but keep getting the error message: Oops! Something went wrong, please try again later. This has been happening for over 2 weeks. Any advice? Thanks!
8 REPLIES 8
ChristineC_24
Thank you! I tried to put a larger amount than the plan cost and it gave me that message. I then tried to only pay the plan cost and still got that message 🤷🏻‍♀️
dust2dust
You used a key word in your question: "custom". Small custom amounts can be made when your balance is over your plan amount. If less then you can only pay your plan amount or more.
ChristineC_24
Thank you!! Maybe I’m locked out because I’ve been trying so many times. Will try again and with *611. Thank you!
ChristineC_24
Thank you for the info!!
ChristineC_24
Thank you!! Will try to get a ticket submitted.
@ChristineC_24   You can only try twice every hour  or your account will be locked temporary for fraud lock,  you will then have to wait a full hour before trying again
Did you try using *611 to make payment?  Try *611 but it needs your 4 digits PIN.  If you forgotten your PIN and your account is still active, login to My Account and reset it first from Profile page
https://selfserve.publicmobile.ca/en/account/my-profile/edit/security-informationhttps://selfserve.publicmobile.ca/en/account/my-profile/edit/security-information
Once you reset the PIN, try using *611 to make payment (again, please wait a full hour first)
@ChristineC_24
Auto pay can fail
To make payment and reactivate plan .. if you know PIN number you can *611 with a voucher and *611  no PIN needed . You can also do this by by calling 18554PUBLIC . otherwise log into self serve make manual payment and reactivate service and or update credit card if necessary
My account
Legend  and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
If you  still have service and your plan renews today / tomorrow you can ignore this suspended notice
if you need further assistance from support to help here’s the link
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
HI @ChristineC_24   if you tried for over 2 weeks, definitely soemthing wrong
But, wait an hour and try again using Incognito/Private/Secret mode first/
if still have problem, then please open ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
