Preferred LTE networks disable receive/make phone calls
fdocruzs
When my preferred network is LTE (recommended), I cannot make or receive phone calls only when I set it to 3G then there is no problem. How/When will this be solved?
8 REPLIES 8
fdocruzs
I switch the card into an Iphone and I have the same problem, only with 3G I can make/receive phone calls (voice), hence I don't think is a bug on my Pixel phone, is something with the network!!
@fdocruzs , there's must be a software bug in the phone.  LTE preferred means exactly that.  If and when 3G service is required, the phone will automatically change network to accommodate.  It seems like your phone is functioning as if it's LTE only.  If reset doesn't resolve the problem, I guess you are stuck with running 3G for now and hope for VoLTE to come along soon.
@fdocruzs wrote:
My phone is a Pixel 4, and the issue started happening a couple of weeks ago, this is my second post, related to this nad basically is always when is set to LTE. And the issue is only with voice, data/text always work fine on either LTE/3G. It is ONLY voice that only works as 3G
@fdocruzs   yes, cos data and text work on BOTH LTE and 3G.  Voice only works on 3G
As said, it looks like a slow switching network on your phone is the cause
Do you see it a non-issue when you are in another area?  Test it out
fdocruzs
Yup, I reset settings, off/on the phone, any other idea?
fdocruzs
hi @fdocruzs   what kind of phone do you have?
if you are on 3G speed plan, it actually ok to leave it in 3G
But you can try your PM sim card in another phone to test out to rule out if it is just a phone issue.
@fdocruzs   PM uses ONLY 3G network for voice and data works on LTE/4G and 3G.  Your phone usually will automatically swtich from LTE to 3G when calls come
it is possible your have weak 3G signal and it takes longer to swtich and unable to grab the 3G signal in time
But, make sure you set our network to Automatic and NOT LTE ONLY.  With LTE Only, your phone won't be able to switch to 3G for voice
Also, do you see this not an issue in different area?  The weak 3G signal could be just a local issue
And what brand and model your phone is ?
Meow
Did you try to reset network settings?
