01-07-2023 10:37 PM
I haven’t be able to receive any texts while in the US. I have the 15 days unlimited talk and text, plus 3G. I’ve turned off my phone and did everything the bot told me to do. I’ve been here three days not, but my account says I still have 15 days left. I’m I missing something?
01-08-2023 09:41 PM
Happened to me in September I got a refund and will never get there add-on for talk and text again I'll get a prepaid in the usa
01-08-2023 12:24 AM
I think you may not have actually completed the purchase of the US add on.
01-08-2023 12:18 AM
Thanks. I just went and checked that out. 👍🏻
01-08-2023 12:15 AM
@DDM69 PM just updated all roaming to 15 days length
they have also re-lineup the roaming add-ons a bit.
01-08-2023 12:14 AM - edited 01-08-2023 12:18 AM
Are you possibly receiving messages using Imessage when connected to a wifi network somewhere?
Did you make sure funds were added to your account when purchasing the US add on?
More info and screenshots would be helpful.
Thanks
01-07-2023 11:32 PM
Yes I did
01-07-2023 11:29 PM
Did you update your carrier profile when you joined public mobile?
01-07-2023 11:25 PM
Thx.
From Apple:
If you must update your iOS do so on wifi or you may use up your available mobile data.
01-07-2023 11:25 PM
on the strings are turned on. Nothing is off or is missing. I really thing it is a public mobile error. Never had this problem on this phone until is switch providers
01-07-2023 11:22 PM
@T-reid @darlicious
Check you phone Setting>Messages>scroll down to Send as SMS then enable (turn on) and same with MMS messaging.
01-07-2023 11:21 PM
imessage strikes again. The welcome text comes from 7626. You need to go in to the imessage options and set send as sms and send as mms to on. Turn on roaming data as well. Of course turn on cellular data when needed.
So you're connected to T-Mobile. Do you have bars? Talk may be spotty but the text and data should be fine.
01-07-2023 11:16 PM
No I didn’t
01-07-2023 11:16 PM
Can you explain the setting the OP needs to enable to recieve SMS/MMS texts?
01-07-2023 11:15 PM
Did you recive the "welcome to the US" text message from 611?
01-07-2023 11:13 PM
I’m in Colorado. I’m on T-Mobile LTE
01-07-2023 11:13 PM
Sorry I'm going on memory for iPhone settings since I'm an android user. There should be a setting to send and recieve SMS/MMS.
01-07-2023 11:04 PM
@HaydenREB PM uses LTE for data and sms for US roaming. Text will work as long as the phone can connect to TMobile LTE/4G network. 3G issue only affect voice, but we can still get voice using PM's T-Mobile 2G network
@T-reid which State and city you are at? your phone able to connect to TMobile? Make sure preferred network type is set to Automatic or 4G. And try to connect to TMobile manully
01-07-2023 11:04 PM
But Imessage is working SMS isn’t
01-07-2023 11:04 PM
Make sure you have SMS/MMS enabled under your messaging settings on your phone.
01-07-2023 11:01 PM
You'll have to turn off iMessage and send text message as a regular SMS
01-07-2023 10:59 PM
I have an iPhone
01-07-2023 10:56 PM
Do you have an iPhone or have RCS (chat features) enabled on your phone? You can recieve SMS texts on your phone without a US Roaming add on so it must be a setting on your phone causing tbe issue.
01-07-2023 10:52 PM
3 gigs of data is what I meant
01-07-2023 10:51 PM
I’ve done both as soon as I got here. Still nothing. People and receive my texts tho
01-07-2023 10:49 PM
I thought 3G doesn’t work in the US?
01-07-2023 10:49 PM
01-07-2023 10:46 PM
Turn on roaming and change the network to T-MOBILE.
