11-21-2023 08:08 PM
Has anyone encountered this issue where you are sometimes unable to make calls?
I set my girlfriend up with Public Mobile 2 days ago and when she tries to make a call it just says "Call Failed". However, she can still receive calls no problem. This happens at home and at work where reception is at 1 or 2 bars.
If this is an issue with cell reception, its a big big problem since she needs to make calls at work and at home! If she switch carriers now, is it possible to get a pro-rated credit/refund?
11-21-2023 08:16 PM
@softech Good catch sir , brain fart
11-21-2023 08:15 PM
Can't that also be a network problem. Something that PM can reset on their side?
11-21-2023 08:14 PM
sorry @Handy1 and @Chalupa_Batman
OP can receive calls but not able to make calls, that's not porting related. It is either device or sim provisioning 🙂
11-21-2023 08:13 PM - edited 11-21-2023 08:19 PM
@Darcho Sounds like a porting issue did you leave old providers SIM card in the phone to reply YES to the transfer ? No worries of not there’s a number for live support will send you it private message and the porting team can re trigger the port request for you
11-21-2023 08:13 PM
Hi @Darcho
Did she port in a number from another service provider? If so the port may not have gone through and she can contact a CS Agent to assist.
If she didn't port and just got a new number, she may need a system reset. She can request that there too.
11-21-2023 08:12 PM
what phone does she have?
Try this
iPhone: Likely no extra work need to do as Telus will enable by default but hide the option. Still you can check
Settings->Cellular->Cellular Data Options->Voice & Data, enable 4G or LTE there
Pixel: Likely no extra work need to do as Telus will enable by default but hide the option. Still you can check
Settings->Network and Internet->Internet, click on the settings icon besides SIM 1, turn on 4G calling there
Samsung/ Other Android: Settings->Connection->Mobile Data, enable VoLTE there
Now, turn off Wifi first. Check if the phone status bar showing it is connected to 4G or LTE
Then make some calls, see if the signal indicator shows LTE or drop back to H or 3G while you are on the calls. If it stays with LTE, then yes, you are using VoLTE, and you can see if calls are any better.
If none of those help, please open ticket with PM support and ask them to reprovision her account on the system
