11-02-2022 05:57 PM
11-03-2022 08:21 PM
imessage strikes again. Did you used to have an iphone? That iphone sender can also turn on send as sms and send as mms and they should be able to send out to you.
11-03-2022 08:16 PM
Hey group,
Figured it out. Turns out iMessage can not be treated as regular text message when you send from iPhone to android. After turn iMessage off in iphone, things look great. Thank you all!
11-03-2022 10:56 AM
@tommy20061222 if you tried on a different phone and same issue, then it might not be a device problem.
I heard of similar issue before and support and reset something on the back end. Maybe open a ticket with them first:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
11-03-2022 10:50 AM
Is there any updates on this? Thank you!
11-02-2022 06:50 PM
The phone brand is Alcatel, android based.
We did try turn on/off wifi, only use data plan, but no luck.
we did our same SIM card into different phone, same problem.
The phone can definitely get incoming calls, I just tried a moment ago.
11-02-2022 06:34 PM
@tommy20061222 What kind of phone is that? brand and model?
Do you get the message when you have Wifi or when you turn on Mobile data? Just want to confirm if the message is true SMS or iMessage/RCS. iMessage/RCS are not SMS and they need data connection (mobile data or wifi)
try to put your PM sim card in another phone to confirm if it works.
Again, it is critical to confirm you are getting incoming calls as it will be a totally different path of troubleshooting.
11-02-2022 06:12 PM
Yes, I can receive incoming phone call.
11-02-2022 06:04 PM
Did you port your old number to PM?
If you can send SMS and call out SIM is working as expected. Answer above question as this is main point if you cannot receive calls/SMS.
11-02-2022 06:01 PM
@tommy20061222 did you port in your phone number from another provider? If so, check if you can receive incoming phone calls as well. If you requested porting , likely the porting was not completed and your old account with another provider is still active.
Check and let us know and will advise further
