Can not make or recieve calls 4 weeks now, No CSA dead end multiple requests bug reports ignored)
RodM1
Also please comment if this has happened to you aswell.
Subject:
Escalation Request – Ongoing Network Issue and Unhelpful Resolution Links
Hello,
I am experiencing a persistent network issue that began 4 weeks ago. Despite my efforts to troubleshoot and confirm that my device and SIM are functioning as they should, the problem remains unresolved.
Key Points:
  1. My SIM card works in another phone, and other SIM cards work in my phone, ruling out hardware issues.
  2. The issue started simultaneously for multiple users, as evident from forum discussions.
  3. Your forum's marked "solved" posts direct users to broken or inaccessible links, such as "Access Denied" pages. This is not a proper resolution, and it discourages users from seeking further help.
My Concerns:
  • It appears the carrier’s system may be bricking service for specific devices or SIM cards.
  • The lack of actionable solutions (e.g., forwarding cases to technical teams or providing clear next steps) is leading to customer dissatisfaction and potentially lost users.
Request for Action:
Please escalate this issue to the Network Engineering or Technical Operations team. This is a network-side issue requiring backend investigation.
Additionally:
  • Please provide confirmation that the broken "resolved" forum links will be reviewed and corrected to prevent further frustration for customers.
  • If there is a team or contact responsible for diagnosing systemic issues like this, I would like their email or other means to submit detailed feedback.
Thank you for addressing this matter seriously. I have attached screenshots of the "Access Denied" forum link and examples of affected users for your reference.
Untitled.jpgUntitled2.jpgUntitled3.jpgUntitled4.jpgUntitled5.jpgScreenshot 2024s-12-05 101019.pngScreenshot 2024-12-05 100952.pngScreenshot 2024-12-05 095655.pngScreenshot 2024-12-05 102440.pngScreenshot 2024s-12-05 101149.png
32 REPLIES 32
@poojamittal728    Are you a new customer, or an existing customer and the phone suddenly stopped working?  We need a bit more information about the situation to have an idea what to suggest.  You might also be better to start a new thread instead of tagging onto this one, so that more people may notice and respond.
poojamittal728
I am unable to make calls
hi @RodM1
complains like this won't go anywhere.  Your  phone is not a model that is sold in North American and certainly not a phone sold by Telus, they don't have full responsibility to assure all phones work on their network.  It is only best effort
@RodM1   Rogers is shutting down 3G altogether in March 2025.  They have a compatibility tool you can try your phone model in, I think you'll find it's not guaranteed to work there either, at least after next March.
https://www.rogers.com/support/mobility/rogers-3g-hspa-networks-are-being-retired
RodM1
Also ive tried it in several areas across the lower mainland and nothing
RodM1
They are telling me there was no update and its not them repeatidly. Id call that fraud and would go to consumer protections and the CRTC.
golfball
We're all just customers here like you. Public Mobile is known to have incomplete support for certain Android phones especially ones that are not Canadian models like Xiaomi.
Your phone may have worked in the past but there are changes made to the network all the time, which can cause issues on devices they don't support properly or are not on their allow list. And it's unlikely that they will do anything to ensure compatibility with as many devices as possible unless forced to by law as they have financial incentive not to.
RodM1
Yes
RodM1
So why did it work fine untill 4 weeks ago. Im connected to a 4g tower can you not use 4g to make calls is it data only? Why would you only have calls on a legacy system that is being shut down without replaceing it thats ridiculous!
hi @RodM1
if data work and just not voice, then yes, it is the lack of 3G netowrk in your area.  You can try in another area
(sorry, your phone is not on PM's VoLTE whitelist and hence you can only use 3G for voice)
RodM1
This is gonna require a few more attempts while waiting instead of frantically doing options in what little free time i have I will update how the attempts to work but to be clear at the moment the name has been set to Public Mobile and the Sim card name is now Telus and I have working data but no phone calls can be made. I am open to any ideas for troubleshooting and would love for this info to be sent to a telus,koodo, bell network admin and would like this to be here as a log for their records.
hi @RodM1
when it connects to LTE, the data work?
you don't connect to EXT or so, you connect only to PM network. And  are you in BC?
RodM1
It connects to LTE and cant do calls but it also cant do calls over 5G and 3G doesnt work at all.
It will fail attempts to connect to EXT 3G
EXT 4G ,EXT 2 G and Bells 4G network
Public Mobile works but no calls can be made or recieved im texting just fine MMS SMS RCS apps use data normally.
Resetting to default does change the name back to PC mobile though so I might have been wrong about the reasoning for it changeing it seems like the default reset sets it to PC mobile
RodM1
Again this brings me to the issue being a carrier issue from an update that bricked my phone and id love to be in contact with a system admin
@RodM1   If it connects on LTE but can't do calls it sounds like a VoLTE problem, that phone is not on the approved list for VoLTE.   When on LTE and you make a call does it try to drop to 3G?
RodM1
With 5 g and LTE i can use the internet but not make calls if 3g doesnt work and that means no calls then why did it all of a sudden stop working. Thats a good idea to try a koodo or telus phone sim card and i could do that right now actually with my work phone and I will try that to try and get an answer here.
RodM1
Still no calls but it connects and works 3 g doesnt work at all though
@RodM1   Everyone here is a customer trying to help.  To get through to a Public Mobile employee you need to submit a ticket - again!
hi @RodM1
the 3G is not connecting and hence you have no calls.  You could be using 3G for data before and hence it is not working
did you try your phone in more than one area?  It seems that some 3G towers are replaced with 4G and we saw some people had problem with 3G voice
generally, because your phone is not a phone for the North American market, I would suggest you think about changing phone
but you can also try to wipe the phone and test again. And if you have friends on Koodo or Telus, try those sim cards on your phone as well
@RodM1   PC Mobile is Bell, Public Mobile is Telus, that's why I was confused to start with until I realized that the APN matched Public Mobile's.  What happens when the phone is on prefer LTE?
golfball
It seems there is an incompatibility with your phone and the network. If you've already tried resetting the network settings or factory resetting the phone it would be easiest to either change phones or switch to another provider. After 4 weeks it doesn't seem that your attempts to escalate are getting anywhere.
RodM1
Changing to prefer 3g has left me with no network at all even data
RodM1
So do i edit this?  I entered those in manually
  1. Open your phone’s settings and tap:
  • Access Point Names
  • New APN settings
  1. Verify the following field match:
RodM1
Its not a different company its just a name for the network. It needed to be changed I deleted the public part partially so that left PC  Public PC I erased the letters inbetween because i needed it to be a different line of text to troubleshoot a different issue and never changed it rebooting after renaming it back is a no go so far.
hi @Phil_Adelphus
wcdma is 3G. when it is 3G, does it even connect?
oh well,  those Asian phone might not work too well here in North America
if you are ready, i suggest yo to wipe the phone and try again
RodM1
Yes I had to name it to something while changeing APN settings years ago to fix a different issue years ago and it worked fine like that for years. Its changed back to Public Mobile if that was the cause of an issue during an update but still no go.
RodM1
It is set to prefer 3g and still no call and i tried the sim in another phone already and vice versa they work. Its just public mobile in my xiaomi doesnt. Every other combination works with the sim including the reader on the dual sim phone i tried that too. Its not hardware How do i check this WCDMA setting?
@RodM1   Oh, so you named it PC Mobile when you really meant Public Mobile.
hi @RodM1
your phone should work ok if you have an international version.   If you have a Chinese version, the voice should still work but data might not work well in 3G
can you try changing your network mode to 3G or WCDMA and check if your phone can connect?
and can you test your sim card on another phone to confirm if it is just a device problem
RodM1
Phones worked fine for several years and yes those are my apn settings along with that copy paste response you have given in other posts. I messaged support and got 6-7 different people all give me various solutions on loop and would not realize the problem is more then the standard script. Everything im seeing here is that this is the result of a poor update to the carrier and simply sending this for a network admin to review a possible rollback on an update 4 weeks ago has gone ignored. Xiaomi Note 12 pro 5G
As for the name that can be anything i saw a post that said that could be called batman but i changed it to public mobile in the general settings and that did nothing but maybe il try turning it off and on again after doing that. I know the issue isnt my phone it makes calls fine with fido sim and the public mobile card works fine in another phone. Settings are automatic and have only ever been changed once when i had an issue of complete no data no awhile back and has been working fine as is till it wasnt 4 weeks ago along with several others
