12-05-2024 01:35 PM
Also please comment if this has happened to you aswell.
Subject: Escalation Request – Ongoing Network Issue and Unhelpful Resolution Links
Hello,
I am experiencing a persistent network issue that began 4 weeks ago. Despite my efforts to troubleshoot and confirm that my device and SIM are functioning as they should, the problem remains unresolved.
Key Points:
My Concerns:
Request for Action:
Please escalate this issue to the Network Engineering or Technical Operations team. This is a network-side issue requiring backend investigation.
Additionally:
Thank you for addressing this matter seriously. I have attached screenshots of the "Access Denied" forum link and examples of affected users for your reference.
12-05-2024 01:49 PM
@RodM1 The invalid html glitch can be resolved by cutting the text out of the post, pasting it into a notes app and then pasting it back again. Alternatively type it all in without copying anything into the text box from a website etc.
I'm a bit confused, your screenshots show both Public Mobile and PC Mobile, two different companies.
12-05-2024 01:38 PM - edited 12-05-2024 01:40 PM
hi @RodM1
you cannot even make calls? what model of phone do you have? maybe it is an incompatible phone. Or was it used without problem before?
and for data and APN, your APN was wrong, why you pick PCMobile, this is Pubic Mobile
usually you can just Reset all networks and the correct APN will be used
if that does not work, manually setup a new on
Next, check your APN settings (Android Phones Only):
if nothing work, just message support using this link
