No data
Ar789
Just changed my plan from a Can US to Can US Mex and now I have no data. The renewal date was this morning and my payment went through. I made no other changes. I’ve been with Public Mobile 10 years. I have restarted the device multiple times and removed the SIM. Nothing is working.
2 REPLIES 2
hi @Ar789
this  happens occasionally after a plan change.  Try Reset network settings.  And if same, ask PM support to refresh your account.   Please submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
slusagm
but voice calls are working? only data is the issue?
Try Reboot phone and Reset network settings.  And make sure mobile data limit is disable
Last, ask PM to check.   Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
