Can-USA-Mex Plan not showing
12-21-2024 09:57 AM
Hi,
Im currently on the $45 plan but would like to switch to the newly offered $35 plan. The $35 plan does not show up for me. This is the second time this has happened but last time they said it was only for new activations or people going to a more expensive plan, which this one does not state.
is there any way I can switch? I would cancel my plan but it is due after the deal expires. What are my options, as I’m thinking of just cancelling and switching to freedom to get on this deal.
thanks you
Plans
12-21-2024 01:17 PM - edited 12-21-2024 01:17 PM
Change to freedom and stay there, that's the best option. Can't say i'll recommend pm to anyone now after these anti-consumer tactics.
12-21-2024 12:43 PM
@BradH123 wrote:Do you know if this has been confirmed? As i do see a $30 20gb plan. I’m a bit scared to lose my current plan and also not be able to get on one of these promo plans.
Let me know if you do go this route .... do an instant renewal to a lower plan and then renewal on the $35 plan. I am on the fence like you. I do not want to change to a lower plan and then not have the $35 option show up.
12-21-2024 11:06 AM
12-21-2024 11:02 AM
Yes, this is what I see.
12-21-2024 10:55 AM
@BradH123 wrote:I have an option for a $20 4g plan that is a low one.
you currently have the $45 plan and when you log in to your account, and view the plan menu available to you...you see the $20 / 4g plan. That is unusual.
12-21-2024 10:41 AM - edited 12-21-2024 10:42 AM
12-21-2024 10:38 AM
12-21-2024 10:29 AM
@BradH123 since you are on the $45 plan right now, what is the cheapest price plan offered to you in your account? I'm on the $34 50GB Canada-US plan and the only cheaper plan I have on offer is $30 20GB Canada-wide, all other plans are more expensive. A possible work-around that was shared in another post was if by chance you have the same $30 option you could switch to that one using "Change now" and then within 24hrs your should be able to see more options to switch to. If you see the one you want, you could then choose "Change on renewal" so that you are not totally wasting money. Keep in mind, the first "Change now" will bill you immediately and you will not get a refund for any unused days from your current subscription but this might be easier than porting out and then porting back in.
12-21-2024 10:17 AM
@BradH123 wrote:Could i switch to the base $20 plan and then on renewal would these more expensive promo plans then appear?
You won't be able to take the $20 plan if you have an expensive plan now. You'd have to get a new sim and start a new account using a different email address. You'd need to take a new number too unless you've ported out to a different provider. It gets kinda complicated and expensive as you can see.
12-21-2024 10:14 AM
@BradH123 wrote:I don’t see any disclaimers. Would this not be false advertising? Is there a group getting together to put in a case?
It is very frustrating indeed. I'm sure there's many "snowbirds" who got snookered into expensive Canada/US/Mx plans who think they can downsize their plan after winter....they're in for a surprise !!
12-21-2024 10:12 AM
12-21-2024 10:11 AM
12-21-2024 10:07 AM
@BradH123 We can only change to the plan that are offered to us in our accounts despite what website says , and it’s harder to downgrade plan price but easy to upgrade plan price the fact you currently pay $45 is why you don’t see the $35 plan . So you could always port number out and back in on Neely created PM account with. New sim and new email to get desired $35 plan and keep same phone number
12-21-2024 10:07 AM
once you have a higher priced plan, PM won't let you downgrade to a cheaper plan now. You can merely take the plans currently avaialble to you.
