7 hours ago
5 hours ago
The same were said over 2 hours ago. Please do not repeat the same info
7 hours ago
we are the person to talk to (but we are not PM staff 🙂 )
want to share your question and we can try to help
But if you need formal PM help, then you will need to open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
7 hours ago
the Community Forum is your first resource for troubleshooting any PM prob's. Let us know what the issue is and I bet we can help.
7 hours ago
Sorry @JD-49 , no phone number to call but you need to open ticket with PM support agent if you need their help
You can submit a ticket with CS Agent using Chatbot https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
