Data
Rat_76
Accepted an offering to increase data to 5 G.  Receiving texts stating I am near limit of 2.5 G (my old limit)????
Rat_76
Thanks!
@Rat_76
It will probably switch over to the new plan on your next renewal date so you won’t be charge for the new plan right away and no refund on used days on your old plan.
Rat_76
6 weeks perhaps.
hi @Rat_76
you should first login My Account and check what is the usage showing there.  If it does show a 2.5 limit there, then it is not right
you can try to ask PM support agent to confirm as well.  You can submit a ticket with CS Agent using Chatbot  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
Jess31
How long ago did you upgrade? Maybe the system did not update yet?
