10-09-2021 06:05 PM - edited 01-06-2022 03:44 AM
I travel to Egypt sometimes and sometimes I need to make phone calls using my Canadian number. So can I make phone calls using my public mobile service in Egypt? And what are fees for roaming in Egypt?
10-10-2021 12:02 PM
Sorry, at Public Mobile service can't be used in Egypt, only in Canada and they offer USA roaming...
10-10-2021 10:09 AM
10-09-2021 08:02 PM - edited 10-09-2021 08:03 PM
@Yummy...from my personal experience.....with TextNow you can call most any Cdn or US number from outside of Canada. As long as you have a robust wifi signal....works great...and it's gratis !!
Most cafes, resorts and other establishments have free wifi...sometimes you just have to ask for their password.
Give it a test drive when you get some time.
10-09-2021 07:41 PM
@Jonya no, there is no roaming other than in USA. Those VoIP app mentioned above is your best option to use overseas to call home. as long as you have WiFi, you can use.
You might want to check if there is prepaid plan in Egypt so you can use data there and the VoIP app will work anytime you have data turned on as well
10-09-2021 07:36 PM - edited 10-09-2021 07:37 PM
@Yummy yes Textnow can be used anywhere in the World with wifi or Mobile Data to call back US and Canada for free. This is the beauty of VoIP app. Other app like Fongo is the same
10-09-2021 07:28 PM
@hairbag1 wrote:alternative is to get free voip app like TextNow. Using wifi, you'll be able to call and text anyone in Canada or USA...for free.
This is interesting... Are you sure one can use TextNow to call USA/Can from overseas???
My impression is you can use TextNow WHILE in USA/Can to call North American number for free AND other countries for small fee. I am not sure you can use it from overseas to call North American number (but I might be wrong).
What works for me is Viber! Easy call to anywhere (but need Viber on the other side of the call).
10-09-2021 06:29 PM - edited 10-09-2021 06:30 PM
@Jonya...once you land in Egypt, you'll find your PM service (talk, text or data) won't work.
There are no add-ons for Egypt...yet.
I'd suggest you get a local sim and a cheap plan while you're overseas. Find a plan there that allows calling back to Canada or wherever you'll be calling.
edit, alternative is to get free voip app like TextNow. Using wifi, you'll be able to call and text anyone in Canada or USA...for free.
10-09-2021 06:11 PM - edited 10-09-2021 06:11 PM
10-09-2021 06:10 PM
No. You can only use phone in Canada or USA..but with an add-on.
