03-19-2025 03:13 PM
My son’s in Brazil and has a public mobile CAN/US subscription. Is there a way for him to continue using his phone while he’s there?
03-19-2025 03:27 PM
@mxw291 wrote:We travel worldwide for work. Purchasing an add-on isn’t an option?
Does that mean Public Mobile won’t work anywhere else beside Canada/USA/MX?
Public Mobile will only work in Canada but does have plans for use while in Mx and USA. Public Mobile plans won't work anywhere else.
03-19-2025 03:23 PM
@mxw291 Does that mean Public Mobile won’t work anywhere else beside Canada/USA/MX?
That's correct. There are some Canadian carriers that don't even work outside Canada at all.
03-19-2025 03:23 PM
@Phil_Adelphus wrote:@mxw291 A workaround would be to download a voip app like TextNow or Fongo and use that to make calls on hotel or other wifi (or cellular data if he gets a data plan there).
Good point, @Phil_Adelphus . If son and you both downloads the free WhatsApp, you'll be able to talk /text for free with him using local wifi. It also works on data if he can buy a local data only plan for cheap.
03-19-2025 03:21 PM
03-19-2025 03:18 PM
03-19-2025 03:15 PM
nope...his Public Mobile will only work while in Canada, US or Mx.
