Reward
Issxn
Hi, I’d like to use my points. Which option includes texts? I can’t find it, thank you.
2 REPLIES 2
funpig1
@Issxn
What plan do you currently have?
Each point is worth $1.
It might be more economical upgrade to the next level of plan to meet your ongoing data or talk needs. Then you can use your points as bill credits to reduce your bills.
Just be aware that once you upgrade, as a general observation, PM makes it very difficult for you to download back to a cheaper plan.
Good luck.
@Issxn
Your base  plan should already included unlimited international text when you are in Canada, so you do not need one (unless you have the very old plan with limited text)
If you are talking about roaming in US, you can buy the 15 days Talk/Text roaming or 15 days Data/Talk/Text roaming Bundle
