08-24-2023 11:44 AM
I am going to Europe in September/October. I want to sign up with Telus while I am there. Can I pause my PM subscription during that time? Thank you.
08-24-2023 08:08 PM
No, it's only about the services before the 30 paid days expires. That's when the 90 days starts. You can still log in to the account. How else would you release the hold. (it used to be called suspend then resume)
The app or the web site.
08-24-2023 07:51 PM
@MetaMorpheusMob- None. There is suspension for lack of payment and then suspension for putting the account on hold. That is done by way of the so-called Lost/stolen function which is now called on hold. The days timer still ticks down until your plan would have otherwise ended. Then the actual 90 days counter starts. But you can release the hold and then the days left will be there from that count of days. (sheesh...did that make sense? 🙂 )
08-24-2023 02:02 PM
HI @Andy-Martin
and @DDM69 was right, it is cheaper to use travel esim or even travel data sim (physical)
08-24-2023 02:00 PM
I was just there for 2 weeks and this worked very well...
08-24-2023 12:55 PM
Thanks I forgot that you need to make a manual payment once your account is suspended.
I amended my response…thanks 😉
08-24-2023 12:48 PM - edited 08-24-2023 12:48 PM
'Manage Subscription - Enable/Disable Auto-Pay'
https://myaccount.publicmobile.ca/en/account/my-payment/manage-subscription
(Make sure to make a payment once every 60-90 days to prevent the Account from closing and your number from being Released.)
08-24-2023 11:53 AM
@BKNS27- Enabling autopay alone won't restart the service. A manual payment needs to be made.
08-24-2023 11:50 AM - edited 08-24-2023 12:54 PM
Yes you can. Just dial 1-855-4PUBLIC and enter your phone number but you will need your security PIN to disable AutoPay (Subscribed).
Remember not to suspend your account longer than 90 days or you will loss your number, SIM will be useless and account will be closed so make a manual payment (because of the suspended on your account) on the 88th day in case any issues.
08-24-2023 11:48 AM - edited 08-24-2023 11:48 AM
@Andy-Martin Yes but don’t let it stay suspended more then 90 days and make sure you make payment no later then that so like day 85 make payment again or before
Turn auto pay OFF/ON 3 easy clicks
Or if you know the 4 digit PIN number
*611
08-24-2023 11:45 AM
HI @Andy-Martin
yes, you can. You can pause for 90 days
Go to My Account, Payment, Manage Subscription and disable Subscribed there. PM won't charge you at the end of this current cycle.
But when you are back, you need to manually make a payment to resume service. And you only have 90 days to pay to resume from the first day of suspension
