Calls
08-30-2022
03:40 PM
08-30-2022
05:42 PM
computergeek541
My calls are going straight to voice mail. It never rings and the settings on my phone have been checked by three different techs with no success. Can someone please help me.
Service
08-30-2022 09:31 PM
@CGO wrote:so only incoming calls unavailable? it might be port issue at network side. you may change the number via self-service or contact cs-agent for troubleshooting.
If there is a porting issue, changing the telephone number willl cause even more complications.
08-30-2022 08:43 PM
08-30-2022 06:33 PM - edited 08-30-2022 06:48 PM
PRIVATE MESSAGE ME
08-30-2022 06:22 PM
Just Telus customers, or Koodo and Public Mobile too? What cell tool is that @NormanWalsh
08-30-2022 06:13 PM - edited 08-30-2022 06:23 PM
I know for a fact thousands of customers are experiencing no incoming calls on and off the past 15 days, for some odd reason telus refuses to tell people they are having hardware problems. I have a network cell tool that shows cell towers and network information. My phone won't ring when noise levels are to low hence going straight to voicemail.
08-30-2022 04:32 PM
@mmrmurphy - is this for a new activation? And if so, was there a number that was ported over to public mobile? This can sometimes be a result of a failed port. Please advise if this is a new ported activation.
Otherwise, there are other good suggestions to try already posted.
Techs, you mean as cell stores? Have they checked if your do not disturb has not been accidentally turned on (I imagine they would have checked this..,but gotta ask).
Also, in the settings of your calling app, there is likely a feature that only allows calls from people that are listed on your contact list to ring. If this setting is turned on, and this is the reason your calls are going to voicemail, then turn this off or add those people to your contact list.
08-30-2022 04:29 PM
08-30-2022 03:52 PM - edited 08-30-2022 03:53 PM
@mmrmurphy Try Settings, Connections, Mobile Networks and Network Mode.. There should be an option for 3G/WCDMA.
08-30-2022 03:50 PM
@mmrmurphy what type of phone do you have?
08-30-2022 03:43 PM
Hi could you tell me how to change to 3G. Thank you
08-30-2022 03:43 PM
@mmrmurphy did you try to reseat your sim card ? turn off the phone, take the sim card out for a minute before you put it back and power up
Also, if you have another phone around, try to put your sim card into it and test it
If you can make outgoing calls, try to change the network to 3G Only and see if you can receive incoming calls
Also, try your phone in another area to see if you can receive calls
08-30-2022 03:42 PM
@mmrmurphy set your network to 3g see if that helps also ,contact a cs agent to ask about your issue you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
