08-30-2022
11:34 AM
08-30-2022
12:50 PM
computergeek541
I cannot open pictures sent to me nor send out pictures. I get the MMS message which has a download box with file size but does not open. ERROR:NETWORK ERROR OCCURED pops up. I have tried many APN settings variations based on info I have but no go. Switched to Public Mobile a week ago. I did not have data at all in the beginning but have since got that going. At wits end now.
edited by computergeek541: miscategorized/not a question about the Community website
08-30-2022 09:34 PM
Your information was correct!
08-30-2022 09:28 PM
Reset network and waalaaa! Thank you and everyone that had me try various things. Now I know my new phone inside and out.
08-30-2022 08:31 PM
08-30-2022 06:16 PM
HI @Bmack ,
did you try to just click Reset Network?
or you tested the sim card on another phone? if you are trying that, please check the APN settings after you put the sim card in the other phone
and if issue persists, open ticket with PM CS agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
08-30-2022 05:59 PM
@dust2dust but he changed it back to blank..um.
I guess it is time to open a ticket with PM support? that have been been some mms (or sms? I forgot) issues lately and they all need to have PM Support involved to get it resovled.
08-30-2022 05:54 PM
@softech- He had tried that earlier. No change.
08-30-2022 05:41 PM - edited 08-30-2022 05:43 PM
@Bmack your main problem is APN Type, it is currently blank, please update:
APN Type: default,supl,mms
I would change the following too:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
and this is the full list for your reference:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
or default,mms,agps,supl,fota,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
08-30-2022 05:31 PM
My current settings. Tried port 8799 and had no internet at all. Tried Name -public mobile and public mobile 2 and no difference. Tried various MMS Proxy suggested and no difference.
08-30-2022 02:43 PM
Hi @Bmack there should be no VPN settings, unless it was a typo and you meant APN
are these couple lines like this? (port 8700 and not 80)
MMS Port: 8799
08-30-2022 02:35 PM
I tried inputting same settings from old phone that sim worked in and lost data completely so rest to original settings. I still get message that "NETWORK ERROR OCCURED" when I try to download pictures sent to me. It seems the same regardless of tried changes in VPN settings. Must be port 80 though. My morning is shot so going to try again this evening.
08-30-2022 01:53 PM
HI @Bmack, when things work perfectly, the APN settings can come down from the network automatically.
But sometimes, we need to give a "kick" by using Reset Network settings, then the APN settings will come down
In other cases, people need to manually change some settings there . Some even needs to start a new APN and enter all the entries. 🙂
08-30-2022 01:50 PM
Then can you match the APN settings from the old phone? (Or did you before?) I would see no reason why the A12 would not do MMS. But stranger things happen.
08-30-2022 01:47 PM
I put my sim in my old phone and it worked perfect immediately with no apn setting changes needed. Wonder what that is telling me?
08-30-2022 12:51 PM
How about another image of your APN settings. And you're still able to browse pages on the internet (not on wifi)?
08-30-2022 12:45 PM
When I try to send pic it just keeps spinning and right now waiting on receiving a new photo. I have tried opening different pics from different contacts I already had. My mobile data is always on and I keep resetting it just in case. Going to try sim card in another phone which I will have available very shortly.
08-30-2022 12:25 PM - edited 08-30-2022 12:26 PM
You had earlier said you couldn't send. Can you try sending an MMS and see what happens. Also try a new inbound as a test. Maybe there's something wrong with the one you're trying to get.
Adding - as always, mobile data on.
08-30-2022 12:23 PM
Again no change. Grrrrr.
08-30-2022 12:19 PM
Ok, try
MMS Proxy = mmscproxy.mobility.ca
MMS port = 8799
Save, airplane mode on/off, turn on data 🙂 , test.
08-30-2022 12:15 PM
Thx for advice but no change.
08-30-2022 11:59 AM
For APN type, put in -> default,mms,supl <- no spaces. Save, go in and out of airplane mode, test.
08-30-2022 11:56 AM
08-30-2022 11:40 AM
Here's a bit of reading for your morning...
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-android-phone
08-30-2022 11:37 AM
Did you turn on data before tapping the item?
Can you provide an image of your APN settings.
