Sim
08-30-2022 05:17 PM
I recently ordered a new sim card online. I activated it but it isn't working on my phone
Service
08-30-2022 09:20 PM
@CGO wrote:Contact cs or send ticket. You can also borrow another active sim from friend and try it on your phone, or go to nearby PM dealer/store for help.
Please do not advise customers to go to a store for assistance with the service. Since Telus purchased Public Mobile, retail locations have never been equiped to provide assistance to existing customers in any form (other than for identification confirmation/account ownership proof issues). In additional, there are no longer any Public Mobile stores or dealers.
08-30-2022 08:23 PM
08-30-2022 08:15 PM - edited 08-30-2022 09:20 PM
@BKNS27 wrote:Did you pick a new number or ported your old number over to PM?
There are extra steps depending on which number.
As the service isn't working, whether the customer has a new number or asked for a number to be ported in wouldn't make a difference.
08-30-2022 07:02 PM
@Blazingleopard Were you successfully charged for the SIM card activation and choice of plan?
As @Yummy also asked, is your account status Active? Log into your My Account to check the status.
08-30-2022 06:05 PM
08-30-2022 05:46 PM
@Blazingleopard you are new PM customer and not replacing old sim card with new sim card, right?
It could be just a sim card provisioning issue. Would be an easy fix for PM support, you just need to open a ticket with them:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
08-30-2022 05:46 PM
But I activated it online
08-30-2022 05:43 PM
I mean it didn't work
08-30-2022 05:43 PM
I didn't
08-30-2022 05:24 PM
@Blazingleopardtake out sim reseat it reboot phone dial *611 to see if it works
08-30-2022 05:24 PM
Sim card is unregistered
08-30-2022 05:23 PM
Nothing is working and I tried it in another phone
08-30-2022 05:22 PM
if you activated new line the contact PM support team by private message CS_Agent to check it.
08-30-2022 05:21 PM
@Blazingleopard - What is the problem you are seeing?
08-30-2022 05:21 PM
Yes it is
08-30-2022 05:21 PM
Did you open self-serving account?
If yes, what foes it say? Is it Active?
Did you get welcome message from PM after opening account?
Does anything work at all? SMS/call/internet?
Can you try your SIM in another phone?
08-30-2022 05:20 PM
@Blazingleopard hi do you have any message on your phone is it unlocked?
08-30-2022 05:20 PM
use browser from computer,and clear cache and cookies and use one page inPrivate mode,
or safari on private mode, To Login Page
check out the right number of new SIM card in your account.
