5 hours ago
5 hours ago
hi @Nicks27
you can find the account number on the Profile page after you login My Account
If you cannot access My Account, please use this link to submit a ticket using the same Community login credentials you are using now: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
5 hours ago
Simply log into your account and under Account. It will show your account number, name and number.
5 hours ago
you need to login My Account or PM app and get it yourself. You will see it under My Account -> Profile page or PM app -> Account page
if you cannot login for any reason, please ask PM to help. Simply open ticket with PM using Expert Messaging. Click the Orange Chatbot icon on the lower right to start, or use this link https://widget.telus.tiia.ai/libs/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&lang=en&toggle=fal...
(For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.)
PM will reply you via Expert Messaging between 9AM-10PM EST (Mon-Sun)
(for help with Expert Messaging, check here: https://publicmobile.ca/en/get-help/articles/expert-messaging )
