08-18-2026 04:19 PM
I just joined PM. My subscription plan is $24-4gb. Under change subscription, there are offer $24-8gb and $25-10gb. Which should I go for ? OR I should wait for better one?
08-18-2026 05:57 PM
i still think you should just take the $24 8GB for now, if you see a better , much better, $25 offer, then jump at that time
and a reminder, if you are changing plan, use Change on Renewal option to schedule a plan change, don't use Change Now
08-18-2026 05:52 PM
$25 a month is my limit. Data is not an issue as I reraly use, but better to have. Now what you think?
08-18-2026 05:42 PM - edited 08-18-2026 06:03 PM
I agree with others, pick what meets your needs. Do you need more data or will you use more data? If not, then perhaps even staying with your current plan is a good option. Hedging risk that in the rare case rates are increased, that will be less likely to be raised or raised less. If more data is useful, then jumping up to a higher data plan for the same price is a no brainer. Plans on offer change all the time, so you can probably wait if nothing is jumping out at you to change to.
08-18-2026 04:36 PM
hi @Jenil_Patel
if you are not in a rush, i would wait. You can get more than 10GB if you choose $25.
08-18-2026 04:26 PM
Welcome
It all depends on what your needs are. The $25 plan is the better price, for sure. For $1 more, you getting an extra 6Gb.
I don't think you will get a better offer really.
Make sure you choose Change on Renewal so that you don't lose any money.
08-18-2026 04:23 PM
i would give with $24 - 8GB for now. Remember it is hard to downgrade, so going to $25 now will likely mean you don't see the $24 plan any more and you might not see go $25 plan too
But of course, if you want to wait, there can be good deals. We saw $25 20GB deals just couple months ago
